Bad display of product volume informations
15 years 2 months ago #24224
by yvanlaer
Bad display of product volume informations was created by yvanlaer
After update to version 1.5.3, there is a bug in the display of each product volume informations (in the front end). If the product as width = "20", it display "2" in the front end. Problem of truncation ?
15 years 2 months ago #24235
Replied by nicolas on topic Re: Bad display of product volume informations
Indeed. Here is the solution:
www.hikashop.com/support/forum/4-how-to/...0.html?lang=en#23619
15 years 2 months ago #24240
by yvanlaer
Replied by yvanlaer on topic Re: Bad display of product volume informations
Thank you. After correction, all run fine !
