solution for predefined ingredients?
- websquirrel
15 years 3 weeks ago #27932
by websquirrel
solution for predefined ingredients? was created by websquirrel
one of my customers want to run an online shop for cosmetics. Each product has a lot of ingredients, that are internatioal standardized. So we would like to establish a database of predefined ingredients that can be easily imported or linked to each product. It would be great if such a database could also be used as a glossary where all ingredients are listed and explained for interested customers.
Does anybody know a good solution for that? Any ideas or extensions that could perform that? I am desperately searching JED, but did not find a good solution yet.
15 years 3 weeks ago #27945
Replied by nicolas on topic Re: solution for predefined ingredients?
How about one of the numerous CCK extensions available for joomla extensions.joomla.org/extensions/news-pr...content-construction ?
That would allow you to build the forms/listings for your data and then some of them can probably display the data in a module which you can include in your products description with the loadposition plugin of joomla.
- websquirrel
15 years 3 weeks ago #27959
by websquirrel
Replied by websquirrel on topic Re: solution for predefined ingredients?
Hm, I never worked with any CCK extension but thank you for the hint. Maybe I should learn to work with such a solution? Still I am afraid it would take me days if not even weeks for such a small feature...
15 years 3 weeks ago #27979
Well, your feature might sounds small to you but each time you want something "custom", it's generally not easy to do unless you code or know a tool to do it.
I still think a CCK is your best bet unless you have some money to hire a freelancer to do it or the knowledge to do it in house.
