Strict Standards:...\plugins\system\hikashopuser\h
14 years 11 months ago #28377 by meiandmyself
finally i found the wat to place a new topic,
can someone help me with remove this problem?
Strict Standards: Only variables should be assigned by reference in... xampp\htdocs\capriccioitalian\plugins\system\hikashopuser\hikashopuser.php on line 66
Strict Standards: Only variables should be assigned by reference in... xampp\htdocs\capriccioitalian\plugins\system\hikashopuser\hikashopuser.php on line 16
i even cant open the top menu in administration side
thank you very much
14 years 11 months ago #28380 by nicolas
You need to deactivate the display or strict errors in the php.ini configuration file of your server. You can find more explanation on that here:
forum.joomla.org/viewtopic.php?p=1223477
14 years 11 months ago #28384 by meiandmyself
can sound stupid but
sorry where i find php.ini?
thanks
14 years 11 months ago #28385 by nicolas
It depends on your web server.
I can see that you're using xampp. So the php.ini should be located in the php folder of your xampp folder.
14 years 11 months ago #28388 by meiandmyself
i have 2 file php .ini
1 is development other is production whichone?
14 years 11 months ago #28389 by nicolas
According to the xampp website there is only one file: \xampp\php\php.ini
www.apachefriends.org/en/xampp-windows.html#1172
14 years 11 months ago #28391 by meiandmyself
but i have two how is possible?
14 years 11 months ago #28392 by nicolas
You can't have twice the same file with the same name in one folder. Could you do a screenshot ?
14 years 11 months ago #28397 by meiandmyself
one name is php.ini.development 68.9 kb
other is php.ini.production 69.2
a piece from the 1st
[PHP]
; About php.ini ;
; PHP's initialization file, generally called php.ini, is responsible for
; configuring many of the aspects of PHP's behavior.
; PHP attempts to find and load this configuration from a number of locations.
; The following is a summary of its search order:
; 1. SAPI module specific location.
; 2. The PHPRC environment variable. (As of PHP 5.2.0)
; 3. A number of predefined registry keys on Windows (As of PHP 5.2.0)
; 4. Current working directory (except CLI)
; 5. The web server's directory (for SAPI modules), or directory of PHP
; (otherwise in Windows)
; 6. The directory from the --with-config-file-path compile time option, or the
; Windows directory (C:\windows or C:\winnt)
; See the PHP docs for more specific information.
; php.net/configuration.file
; The syntax of the file is extremely simple. Whitespace and Lines
; beginning with a semicolon are silently ignored (as you probably guessed).
; Section headers (e.g. [Foo]) are also silently ignored, even though
; they might mean something in the future.
; Directives following the section heading [PATH=/www/mysite] only
; apply to PHP files in the /www/mysite directory. Directives
; following the section heading [HOST=www.example.com] only apply to
; PHP files served from www.example.com . Directives set in these
; special sections cannot be overridden by user-defined INI files or
; at runtime. Currently, [PATH=] and [HOST=] sections only work under
; CGI/FastCGI.
; php.net/ini.sections
; Directives are specified using the following syntax:
; directive = value
; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
; Directives are variables used to configure PHP or PHP extensions.
; There is no name validation. If PHP can't find an expected
; directive because it is not set or is mistyped, a default value will be used.
; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
; (e.g. E_ALL & ~E_NOTICE), a quoted string ("bar"), or a reference to a
; previously set variable or directive (e.g. ${foo})
; Expressions in the INI file are limited to bitwise operators and parentheses:
; | bitwise OR
; ^ bitwise XOR
; & bitwise AND
; ~ bitwise NOT
; ! boolean NOT
; Boolean flags can be turned on using the values 1, On, True or Yes.
; They can be turned off using the values 0, Off, False or No.
; An empty string can be denoted by simply not writing anything after the equal
; sign, or by using the None keyword:
; foo = ; sets foo to an empty string
; foo = None ; sets foo to an empty string
; foo = "None" ; sets foo to the string 'None'
; If you use constants in your value, and these constants belong to a
; dynamically loaded extension (either a PHP extension or a Zend extension),
; you may only use these constants *after* the line that loads the extension.
; About this file ;
; PHP comes packaged with two INI files. One that is recommended to be used
; in production environments and one that is recommended to be used in
; development environments.
; php.ini-production contains settings which hold security, performance and
; best practices at its core. But please be aware, these settings may break
; compatibility with older or less security conscience applications. We
; recommending using the production ini in production and testing environments.
; php.ini-development is very similar to its production variant, except it's
; much more verbose when it comes to errors. We recommending using the
; development version only in development environments as errors shown to
; application users can inadvertently leak otherwise secure information.
; Quick Reference ;
; The following are all the settings which are different in either the production
; or development versions of the INIs with respect to PHP's default behavior.
; Please see the actual settings later in the document for more details as to why
; we recommend these changes in PHP's behavior.
; allow_call_time_pass_reference
; Default Value: On
; Development Value: Off
; Production Value: Off
; display_errors
; Default Value: On
; Development Value: On
; display_startup_errors
; Default Value: Off
; error_reporting
; Default Value: E_ALL & ~E_NOTICE
; Development Value: E_ALL | E_STRICT
; Production Value: E_ALL & ~E_DEPRECATED
; html_errors
; Default Value: On
; Production value: Off
; log_errors
; Production Value: On
; magic_quotes_gpc
; Default Value: On
; max_input_time
; Default Value: -1 (Unlimited)
; Development Value: 60 (60 seconds)
; Production Value: 60 (60 seconds)
; output_buffering
; Development Value: 4096
; Production Value: 4096
; register_argc_argv
; Default Value: On
; register_long_arrays
; Default Value: On
; request_order
; Default Value: None
; Development Value: "GP"
; Production Value: "GP"
; session.bug_compat_42
; Default Value: On
; session.bug_compat_warn
; Default Value: On
; session.gc_divisor
; Default Value: 100
; Development Value: 1000
; Production Value: 1000
; session.hash_bits_per_character
; Default Value: 4
; Development Value: 5
; Production Value: 5
; short_open_tag
; Default Value: On
; track_errors
; url_rewriter.tags
; Default Value: "a=href,area=href,frame=src,form=,fieldset="
; Development Value: "a=href,area=href,frame=src,input=src,form=fakeentry"
; Production Value: "a=href,area=href,frame=src,input=src,form=fakeentry"
; variables_order
; Default Value: "EGPCS"
; Development Value: "GPCS"
; Production Value: "GPCS"
; php.ini Options ;
; Name for user-defined php.ini (.htaccess) files. Default is ".user.ini"
;user_ini.filename = ".user.ini"
; To disable this feature set this option to empty value
; TTL for user-defined php.ini files (time-to-live) in seconds. Default is 300 seconds (5 minutes)
;user_ini.cache_ttl = 300
; Language Options ;
; Enable the PHP scripting language engine under Apache.
; php.net/engine
engine = On
; This directive determines whether or not PHP will recognize code between
; <? and ?> tags as PHP source which should be processed as such. It's been
; recommended for several years that you not use the short tag "short cut" and
; instead to use the full <?php and ?> tag combination. With the wide spread use
; of XML and use of these tags by other languages, the server can become easily
; confused and end up parsing the wrong code in the wrong context. But because
; this short cut has been a feature for such a long time, it's currently still
; supported for backwards compatibility, but we recommend you don't use them.
; Default Value: On
apiece of the 2nd
[PHP]
; About php.ini ;
; CGI/FastCGI.
; directive = value
; | bitwise OR
; ^ bitwise XOR
; & bitwise AND
; ~ bitwise NOT
; ! boolean NOT
; About this file ;
; Quick Reference ;
; Default Value: On
; display_errors
; Default Value: On
; error_reporting
; html_errors
; Default Value: On
; log_errors
; magic_quotes_gpc
; Default Value: On
; max_input_time
; output_buffering
; Default Value: On
; Default Value: On
; request_order
; Default Value: On
; Default Value: On
; Default Value: 4
; short_open_tag
; Default Value: On
; track_errors
; url_rewriter.tags
; variables_order
; php.ini Options ;
; php.net/engine
engine = On
; Default Value: On
; php.net/short-open-tag
short_open_tag = Off
; Allow ASP-style <% %> tags.
; php.net/asp-tags
asp_tags = Off
; The number of significant digits displayed in floating point numbers.
; php.net/precision
precision = 14
; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
; php.net/y2k-compliance
y2k_compliance = On
; Output buffering is a mechanism for controlling how much output data
; (excluding headers and cookies) PHP should keep internally before pushing that
; data to the client. If your application's output exceeds this setting, PHP
; will send that data in chunks of roughly the size you specify.
; Turning on this setting and managing its maximum buffer size can yield some
; interesting side-effects depending on your application and web server.
; You may be able to send headers and cookies after you've already sent output
; through print or echo. You also may see performance benefits if your server is
; emitting less packets due to buffered output versus PHP streaming the output
; as it gets it. On production servers, 4096 bytes is a good setting for performance
; reasons.
; Note: Output buffering can also be controlled via Output Buffering Control
; functions.
; Possible Values:
; On = Enabled and buffer is unlimited. (Use with caution)
; Off = Disabled
; Integer = Enables the buffer and sets its maximum size in bytes.
; Note: This directive is hardcoded to Off for the CLI SAPI
; php.net/output-buffering
output_buffering = 4096
; You can redirect all of the output of your scripts to a function. For
; example, if you set output_handler to "mb_output_handler", character
; encoding will be transparently converted to the specified encoding.
; Setting any output handler automatically turns on output buffering.
; Note: People who wrote portable scripts should not depend on this ini
; directive. Instead, explicitly set the output handler using ob_start().
; Using this ini directive may cause problems unless you know what script
; is doing.
; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
; Note: output_handler must be empty if this is set 'On' !!!!
; Instead you must use zlib.output_handler.
; php.net/output-handler
;output_handler =
; Transparent output compression using the zlib library
; Valid values for this option are 'off', 'on', or a specific buffer size
; to be used for compression (default is 4KB)
; Note: Resulting chunk size may vary due to nature of compression. PHP
; outputs chunks that are few hundreds bytes each as a result of
; compression. If you prefer a larger chunk size for better
; performance, enable output_buffering in addition.
; Note: You need to use zlib.output_handler instead of the standard
; output_handler, or otherwise the output will be corrupted.
; php.net/zlib.output-compression
zlib.output_compression = Off
; php.net/zlib.output-compression-level
;zlib.output_compression_level = -1
; You cannot specify additional output handlers if zlib.output_compression
; is activated here. This setting does the same as output_handler but in
; a different order.
; php.net/zlib.output-handler
;zlib.output_handler =
; Implicit flush tells PHP to tell the output layer to flush itself
; automatically after every output block. This is equivalent to calling the
; PHP function flush() after each and every call to print() or echo() and each
; and every HTML block. Turning this option on has serious performance
; implications and is generally recommended for debugging purposes only.
; php.net/implicit-flush
; Note: This directive is hardcoded to On for the CLI SAPI
implicit_flush = Off
; The unserialize callback function will be called (with the undefined class'
; name as parameter), if the unserializer finds an undefined class
; which should be instantiated. A warning appears if the specified function is
; not defined, or if the function doesn't include/implement the missing class.
; So only set this entry, if you really want to implement such a
; callback-function.
unserialize_callback_func =
; When floats & doubles are serialized store serialize_precision significant
; digits after the floating point. The default value ensures that when floats
; are decoded with unserialize, the data will remain the same.
serialize_precision = 100
; This directive allows you to enable and disable warnings which PHP will issue
; if you pass a value by reference at function call time. Passing values by
; reference at function call time is a deprecated feature which will be removed
; from PHP at some point in the near future. The acceptable method for passing a
; value by reference to a function is by declaring the reference in the functions
; definition, not at call time. This directive does not disable this feature, it
; only determines whether PHP will warn you about it or not. These warnings
; should enabled in development environments only.
; Default Value: On (Suppress warnings)
; Development Value: Off (Issue warnings)
; Production Value: Off (Issue warnings)
; php.net/allow-call-time-pass-reference
allow_call_time_pass_reference = Off
; Safe Mode
; php.net/safe-mode
safe_mode = Off
; By default, Safe Mode does a UID compare check when
14 years 11 months ago #28398 by nicolas
It's neither of them. The php.ini must be called php.ini and not php.ini.production or php.ini.development.
Then, if you don't have that file in there it must be somewhere else.
Go there on your back end:
backend (administrator) -> help -> system info -> PHP Information Tab -> 6th block down -> Configuration File (php.ini) Path
will show you the path to the php.ini file in your installation.
14 years 11 months ago #28400 by meiandmyself
that is what u mean: Configuration File (php.ini) Path C:\Windows
14 years 11 months ago #28401 by meiandmyself
of this? Configuratie-instellingen (.ini)property
14 years 11 months ago #28403 by meiandmyself
in this lastone there is no sentence about error reporting
14 years 11 months ago #28405 by meiandmyself
i really cant find help?
i tried to restrat but go on as before
14 years 11 months ago #28406 by nicolas
Yes, it's that entry in the system info : Configuration File (php.ini)
That should give you a full path to your php.ini file that you need to edit to remove these messages.
14 years 11 months ago #28408 by nicolas
Alternatively, there is also an option in the global configuration of joomla in the server settings. There, you will see ERROR REPORTING. Simply change the level in this dropdown so that it doesn't display the error messages.
14 years 11 months ago #28411 by meiandmyself
Configuration File (php.ini) says in c window but under bring me foer the full street in the folder of xaamp PHP php.ini that u said was not good, however now i erased xaamp 174 and try with 173 so joomla is not visible now, i'm trying to give my best but i go so down. i let you know soon how go
14 years 11 months ago #28426 by meiandmyself
i installed again xaamp, joomla, and hikashop.
i put down the error reporting in joomla, i selected none.
however i cant find a file php.ini, but again php ini development and ini production
i dont know how to do i get again a stric standard error message
14 years 11 months ago #28427 by meiandmyself
the problem is that i cant work with the top menu on admin side
please any ideas?
14 years 11 months ago #28447 by nicolas
I just installed xampp on my computer to check on where that php.ini file was.
I found it there : C:\xampp\php\php.ini
So If you installed it with the default settings, that's where you should see it too.
Time to create page: 0.347 seconds
