Problem with seo
14 years 9 months ago #37487 by thanos
Problem with seo was created by thanos
Hello , i use joomla 1.73 and hikashop bisiness.
I have created a menu structure to display my products.
I used in some menus type of content category and in others type of content product.
If the seo settings of joomla are disabled everything works ok.
If the seo are enabled the menus that have type of content category are not working ok.
Could you please help?
Thanos
14 years 9 months ago #37584 by nicolas
Replied by nicolas on topic Re: Problem with seo
Sure. What kind of error do you get when you activate the SEO ?
Could you do a screenshot ?
Could you give a link to your shop maybe ?
Are the other menus of your website working properly when activating the SEO ?
14 years 9 months ago #38160 by thanos
Replied by thanos on topic Re: Problem with seo
So sorry for the delay , but i was out of office for 3 days.
The problem i had was because i had category sef name: none.I entered a name and everything works ok.
My questions are :
1. can i remove both the category sef name and product sef name
2. Can i remove the number that shows in the links (it is the category id and the product id)
3. Can i send you the domain name hidden
Thanos
14 years 9 months ago #38265 by nicolas
1. No, only one of the two.
2. No, that is used to identify the entity (product or category) to use
3. Sure, by pm for instance, but if it works, then we don't need it :)
14 years 9 months ago #38399 by thanos
ok
Thanks Nicolas
