Module Class Suffix Problem
14 years 9 months ago #38031 by Pit Pony
I am using Joomla 2.5 with Business version of Hikashop.
Have tried to add css style to 'mod_hikashop_cart' using Module Class Suffix and it wont show up in code.
Have tested a standered Joomla 2.5 module and have no problem.
14 years 9 months ago #38125 by nicolas
The class on modules is added by the template. On some positions, the class might not be added to the module. You should try to set the cart module to the same position as your other module for which it's working.
14 years 9 months ago #38134 by Pit Pony
Hi Nicolas
First thing I tested, have just tested again... Joomla module works ok still a problem with hikashop module.
14 years 9 months ago #38212 by nicolas
That's the only solution I can see. Did you try other positions ? Is the hikashop module using the same chrome as your other modules ?
docs.joomla.org/Module_chrome
You should check the style attribute (equivalent to chrome) of the position of your template to which you assigned the module.
The best is to use the default style so that it uses the module_menu class.
As I said, the class is displayed by the template, not by the module. So there is nothing we can do from HikaShop's end.
14 years 9 months ago #38279 by Pit Pony
Hi Nicolas
Had a look at template and the style assigned is "Jaw", have tried altering as suggested but throws out appearance of other modules...
I think the work around will be custom joomla html modules with loadposition for the hikashop element...
