- Thank you received: 6
Product Not Found
- artisanwebandprint
14 years 5 months ago #49167
by artisanwebandprint
Product Not Found was created by artisanwebandprint
I'm using Joomla 2.5.4 and started with the free Hika Shop version. I just took the plunge and upgraded to the business edition. I installed it according to the instructions and now the products do not show up when I click on a category listing on the front end. I see the products listed on the backend, they are attributed to the category, they have a quantity however I get an error message "Product not found" on the front end. In the free version all of the products showed up when I clicked on their respective category. I've also turned on all display options for modules, etc.
king.artisanwebandprint.com
Thanks,
Dawn
Thanks,
Dawn
- Thank you received: 1778
14 years 5 months ago - 14 years 5 months ago #49231
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Product Not Found
If you are showing a category you shouldn't have the error message "Product not found", so I think that the error come from the "menu" option of your module that you can edit in " System -> Display -> content modules ".
You should edit the module with the ID 100 there and set the field "menu" to a menu of the type "hikashop category listing".
Last edit: 14 years 5 months ago by nicolas. Reason: more accurate text
14 years 5 months ago #49269
Replied by artisanwebandprint on topic Re: Product Not Found
I set the display>module id #100 to "menu" Portfolio which is a category listing menu item. The categories all show up as an image with the name of the category above it. When I click on the category I get the "products listing" for that category and the error message "Product Not Found".
king.artisanwebandprint.com/portfolio/Portfolio/13-mexico
I will private message you with login so you can see.
Thanks,
Dawn
Thanks,
Dawn
14 years 5 months ago #49273
by Mohamed Thelji
The problem was coming from your "SEF url options" in "Hikashop -> system -> configuration" because you can't set the same value for the Category and Product SEF name.
14 years 5 months ago #49746
Merci Beaucoup!
