Can't see Related Products module
- unclefudgly
14 years 5 months ago #52927
by unclefudgly
Can't see Related Products module was created by unclefudgly
I am in the process of moving 3 shops from Redshop to Hikashop, because I think overall your solution is better. Saying that I cannot grasp your use of modules as I never use them.
I have added a related products content module as directed in help file, but it does not show up beneath products.
I have set the shop up as follows Create Joomla menu item to point to hikashop categories listing, saved, then set hikashop options to display my selected category. This works I see my category and all it's products displayed, and when I click on an item I see the product. But I never see related products or previous/next shortcuts, which I have also turned on.
Any ideas what's missing?
14 years 5 months ago #53013
Replied by nicolas on topic Re: Can't see Related Products module
For the previous/next buttons, you should see them on each product page if you turn on the "Show shortcuts to other category products" option of the Display tab of the configuration.
For the related products module, you need to follow the procedure here:
www.hikashop.com/en/support/documentatio...ct-form.html#related
If it doesn't work, it means that one of the step you did is not correct.
Could you post screenshots of the different steps you did ?
- unclefudgly
14 years 5 months ago #53066
by unclefudgly
Replied by unclefudgly on topic Re: Can't see Related Products module
I fixed the previous next buttons issue. Because I am heavily styling the shop I edited the "product/show" view in content views to remove them initially, and forgot to reinstall them, so all looking good now. The related products module was as you said just an error, did it again and looks ok now.
thanks for your time
