- Thank you received: 1
Add to cart popup nav bars and size problem-SOLVED
- amin.gomez
14 years 2 months ago - 14 years 2 months ago #64189
by amin.gomez
Add to cart popup nav bars and size problem-SOLVED was created by amin.gomez
I have a problem with the add to cart button, the popup shows navigation bars and the size of the popup is to large.
mercando.algom.co/index.php/mercar
Last edit: 14 years 2 months ago by amin.gomez.
14 years 2 months ago #64253
Replied by nicolas on topic Re: Add to cart popup navigation bars and size problem
That comes from the CSS:
body {
min-width: 960px;
.rt-container {
margin: 0 auto;
width: 960px;
which is in the CSS file mercando.algom.co/libraries/gantry/css/gantry.css of your template.
If you remove that CSS, it will display fine.
body {
min-width: 960px;
.rt-container {
margin: 0 auto;
width: 960px;
- amin.gomez
14 years 2 months ago #64367
by amin.gomez
Replied by amin.gomez on topic Re: Add to cart popup navigation bars and size problem
Hi, if i remove that code from the css, it works, but it affects the overal layout of the tamplate (as in the image), all the template align to the left. Can you help me with this?
- amin.gomez
14 years 2 months ago #64445
by amin.gomez
can somebody help me?
- amin.gomez
14 years 2 months ago #64501
by amin.gomez
hi, the rockettheme team help me with this, here is the their answer:
1.
Open component.php in your template folder
Find <body> and change it to
<body style="min-width: 200px">
Save that.
2.
Add this to your css
body > #rt-main div.rt-container { width: auto;}
3.
Clear your browser-cache ...
....and it worked perfect
1.
Save that.
2.
3.
The following user(s) said Thank You: djundi
