Problem with width auto in chrome
- condorazul
14 years 2 months ago #65151
by condorazul
Problem with width auto in chrome was created by condorazul
I dont know since when i have this problem but if you go to
www.lacestamagica.com
surfing on chrome, the width:auto sets the width to the 100% and brokes image dimensions, you can see it surfing on ie or firefox, any help?
- condorazul
14 years 2 months ago #65153
by condorazul
Replied by condorazul on topic Re: Problem with width auto in chrome
Ok i found the problem and i left the answer if anyone has the same problem. if you set max-heigt:x px; and width:auto; you need to set height:auto; for chrome to redimension the image in proportion.
12 years 6 months ago #154231
by abstractimagegroup
Abstract Image Group | Fulfilling all of your large format printing needs!
Replied by abstractimagegroup on topic Re: Problem with width auto in chrome
What css file did you edit to achieve this?
- condorazul
12 years 6 months ago #154232
by condorazul
I usually use yootheme so i do it in my custom.csd but you can do it in the hikashop frontend css wich can be modified in configuration display
