Organizing Promo products
14 years 1 month ago #66402 by ClickWebDesign
Hi Guys,
I'm putting together a "request a quote" style website (pricing not important or displayed for quote only) using Hika for a promotional products website. Trying to work out the best approach for managing variants, characteristics etc.
All products have a order quantity characteristic. Unfortunately they vary and maybe 2-5 products share the same order quantity set, ie:
25, 50, 100, 200
then another
250, 500, 1000, 2000
as well there is normally a Print colors characteristic:
1,2,3,not sure
or
1,2,3,4,not sure
Then usually a color variation or similar. this is the only setting that might require changing an image.
What do you think will be the easiest/least confusing way for the client to add their own products (potentially 100's) after handover?
Is it possible to create a "super-set" of quantity and disable depending on the product?
If I create 3 variants do I need to set the color image multiple times for each combination?
Thanks in Advance & let me know if more info is required,
Chris
14 years 1 month ago #66451 by Mohamed Thelji
Hi Chris,
1. I didn't realy understood your question, can you explain it to me :) ?
2. No not necessarily, You can set your "default" pictures through your main product and this main product's variants will take your "default" picture.
14 years 1 month ago #66559 by ClickWebDesign
Thanks Mohamed,
Wondering what the best way to organise the 3 characteristics per product would be.
I could end up with 10-15 different characteristics for quantity alone, as there are different sets for different products. Just a thought would be if I could create a characteristic (or something simular with options/custom fields) that contained all the different quantities, assign it to a product and select which quantities to appear?
When viewing the characteristics there is no way to quickly tell which quantity set has which quantities without clicking on each one.
Chris
14 years 1 month ago #66805 by nicolas
You can have just one characteristic with all the values.
Then, once you add your characteristics to a product, you can click on the "manage variants" button and delete all the ones you don't need.
Note that over a few hundred of variants, your server won't be able to handle the load on some pages resulting in blank pages. If you have too many of them, I would recommend to not use a characteristic for the quantity but to use the normal quantity system:
www.hikashop.com/en/forum/4-how-to/15254...uantity-ordered.html
and:
www.hikashop.com/forum/4-how-to/60489-al...s.html?lang=ja#60684
14 years 1 month ago #66884 by ClickWebDesign
Hi Guys,
I ended up using options to avoid variant combinations and named them
Quantity25-500
Quantity100-1000
etc
To give an idea of the range to help with selection. Thanks for your help,
Chris
14 years 1 month ago #67213 by EricaJohnns
That is a wide range. I prefer simpler range or shorter range but if you are okay with that, go on B)
www.funpromotionalproducts.com
Promotional Products Supplier – Personalized Executive Gift Items - Fun Promotional Products
13 years 10 months ago - 13 years 10 months ago #83673 by joshef
Replied by joshef on topic Organizing Promo products
There are some companies which supply promotional product to other companies and organization at a marginal rates. There are various item like t-shirt, pens, torch, caps, calculators, pen drives, etc. you can select the product of your choice and can give demand to these companies.
promo products for various companies
Last edit: 13 years 10 months ago by joshef.
