- Thank you received: 1
prob with content & cart modu in the same position
- amin.gomez
14 years 1 month ago - 14 years 1 month ago #67195
by amin.gomez
prob with content & cart modu in the same position was created by amin.gomez
Hi Nicolas, i,ve made a some customization to our site: now the choose product button works in popup window.
The problem is that i have a content module ("productos destacados") and the cart module in the same position:
content module= maintop a
cart= maintop b
checkin the code i noticed something different in the button url, it has "itemid=0", something that the other content modules doesn't have. If i change the module position itemid=0 dissapear, but i don't have any other position to put the cart.
Can you help me?
mercando.algom.co/
PD= the popup is different with that problem, it shows th entire page. In the other module "productos en descuenos" it shows ok, only the product.
cart= maintop b
Can you help me?
mercando.algom.co/
Last edit: 14 years 1 month ago by amin.gomez.
- amin.gomez
14 years 1 month ago #67210
by amin.gomez
Replied by amin.gomez on topic Re: prob with content & cart modu in the same position
somebody?
14 years 1 month ago #67337
Replied by nicolas on topic Re: prob with content & cart modu in the same position
In the hikashop options of each module, you can select the option "menu" of the module which will define the itemid (the id of the menu) which will be used for the links of the module.
You should check that this module has the same value for that option than the other modules.
