Export products
14 years 4 weeks ago #70429 by fashiony
Export products was created by fashiony
Im trying to export Products, and it breaks after 11000 products, so i select 111 and select all that gives me 500 products (ID 11500-11599) to export and it only show me white screen, i was trying with 116 and thats the same. All went well upp to 111, the 106 went well.
Any solutions?
Also any tip how to export all products in one click?
14 years 4 weeks ago #70463 by nicolas
Replied by nicolas on topic Re: Export products
If you get a white screen, it's likely to come from restrictions on your hosting.
Set the "error reporting" option of the joomla configuration to maximum and that will display you the error message.
That will either be a memory limit or a maximum execution timeout.
Then, you can ask your hosting to increase the setting of your php.ini which limits the export.
Time to create page: 0.040 seconds
