- Thank you received: 8
Problem with currency
- parsanches
14 years 4 weeks ago #70531
by parsanches
Problem with currency was created by parsanches
14 years 4 weeks ago #70534
Replied by nicolas on topic Re: Problem with currency
There is a "Help" button on which you can click on each screen of the backend where it explains what the settings do.
There, you will see that:
So basically, just change that format option of your currency as explained.Format : The way you want to display the symbol (basically you will have %i which will display the currency code as symbol, %n which will display the currency's symbol and %ni which will display both). For more information, you can look at www.php.net/manual/en/function.money-format.php
- parsanches
14 years 4 weeks ago #70542
by parsanches
Replied by parsanches on topic Re: Problem with currency
Thanks. it works)
