search problem
14 years 1 week ago #74044
by fnuus
search problem was created by fnuus
I have a question.
Both Hikashop Search plugins ar enabled. but when i try for example to find fm 052 or 052 he will find one product. and there a lot more product with 052 or FM 052.
How can i change this so that the search engine will find the products ?
With friendly regards,
Fred
I have a question.
Fred
14 years 1 week ago #74151
by Eliot
Replied by Eliot on topic Re: search problem
Hi Fred,
Are you sure the menu you linked to the search plugin contain the products you are looking for?
This may be the source of the problem
14 years 1 week ago #74166
by fnuus
Replied by fnuus on topic Re: search problem
Sorry, but i don't understand what you mean with make an link between menu and plugin !!
Fred
Fred
14 years 1 week ago - 14 years 1 week ago #74167
by Eliot
You probably activated the Hikashop search plugin or a filter to make this search field.
In the configuration of these objects you can choose which menu is linked to the search module. It's the menu in which the search will be done.
You should take a look at it.
EDIT: If it's a filter, make sure the category selected is the good one and that the "Including sub categories" option is activated. Could you by the way post a link to your website so I can try it?
Last edit: 14 years 1 week ago by Eliot.
14 years 1 week ago #74177
by fnuus
I did what you sayd, i selected the category. In the filter i make choices for product_code, Description,
And now i published it on my site, but i get nothing.
This is the link ! Hanons
Fred
Fred
14 years 1 week ago - 14 years 1 week ago #74180
by Eliot
Could you please post a screenshot of your filter?
You should add product_name as well
14 years 1 week ago #74192
by fnuus
14 years 1 week ago #74364
Replied by nicolas on topic Re: search problem
The problem is that in the options of your filter module, you need to enter in the "menu" option the id of a products listing menu item displaying all your products. There is such menu item created by default by HikaShop so you just need to get its id there.
13 years 1 month ago #123669
by lionel75
Replied by lionel75 on topic Re: search problem
Is there a tutorial or documentation about search extension implemented by hikashop compare to default joomla functionnalities ?
thank's
thank's
13 years 1 month ago #123761
by Xavier
Replied by Xavier on topic Re: search problem
Here is the documentation about filters:
www.hikashop.com/support/2013-08-08-00-1...hop-filter-form.html
