Update to 2.0, i have two versions in backend.HELP
14 years 5 days ago - 14 years 5 days ago #75410 by dado023
Instead of explaining, please take a look at the picture:
www.webpagescreenshot.info/i/20579-119201285820pm.png
Which one do i pick to update? AND WHY DO I HAVE TWO SAME HIKASHOPS to update?
Last edit: 14 years 5 days ago by dado023. Reason: sry, CAPS
14 years 5 days ago #75442 by nicolas
You don't have two hikashops. It's just that for some reason the entry in the table managing the updates is doubled for HikaShop.
You can update any one and that should be ok.
14 years 5 days ago #75457 by dado023
I made two same updates to make it go away, but that is not normal solution
How do i make this right, so it doesn't display two Hikashops.
14 years 4 days ago #75492 by nicolas
No one had the problem and we can't reproduce it so I can't say exactly why.
If you want to remove one of the two, go in your phpmyadmin and look at the table jos_update_sites and remove one of the two entries for HikaShop.
