Adress in navigation bar problem
- condorazul
14 years 4 days ago #75591
by condorazul
Adress in navigation bar problem was created by condorazul
i have this adress for a product:
http://localhost/miraur/linea-esencial/leche-limpiadora-de-tratamiento-miraur
but when i get to the product it changes to
http://localhost/miraur/linea-esencial/leche-limpiadora-de-tratamiento-miraur#.UJ7aIoZBEbB
is that normal?
i´m going to upload de web to miraur.pingraf.es in a few minutes ready
is that normal?
14 years 2 days ago #75843
by Eliot
Replied by Eliot on topic Adress in navigation bar problem
Hi there,
I must admit that I don't see where this thing can come from but it's definitely not because of Hikashop.
You should check your extensions to see if something may be at the source of the problem.
- condorazul
14 years 2 days ago - 14 years 2 days ago #75847
by condorazul
Replied by condorazul on topic Adress in navigation bar problem
Elliot it happens after clicking on the image to see it bigger and then one you do it one time it stills there
Last edit: 14 years 2 days ago by condorazul.
14 years 2 days ago #75851
by Eliot
- condorazul
14 years 2 days ago #75876
by condorazul
Thank you very much i didnt know even how to look for it thank you
- condorazul
14 years 2 days ago #75877
by condorazul
The solution for others if they have the same problem
<script type="text/javascript">
var addthis_config = addthis_config||{};
addthis_config.data_track_addressbar = false;
</script>
</script>
