- Thank you received: 8
Wishlist showing as a cart when not logged in...
14 years 3 days ago - 14 years 3 days ago #75692
by ianspeed
Wishlist showing as a cart when not logged in... was created by ianspeed
Hi Nicolas, hope you are well...
Have just had to put a site live on the Hikashop business package...
Unfortunately I think there may be a problem with the wishlist, as it shows cart in the heading when you display wishlist and ask you if you want top add from cart to wishlist...If you log in as admin it seems to be fine..sometimes.
Also, when drilling down through categories the breadcrumb gets broken after entering the sub category...Which means the user has to go back up two pages on the breadcrumb to get back to where they were. Any Ideas how to get around this?
Ian
Ian
Last edit: 14 years 3 days ago by ianspeed. Reason: typo
14 years 1 day ago #76061
by Xavier
Replied by Xavier on topic Wishlist showing as a cart when not logged in...
Thanks for the report, to correct the wishlist display when not logged in, can you edit the file: "components/com_hikashop/views/cart/view.html.php" in the function "showcart()" add the line:
Before:
Concerning the breadcrumbs, that's because you are using the "Simplified breadcrumbs", disable this option in HikaShop > Configuration > Main.
JRequest::setVar('cart_type',$cart_type);
$module = hikashop_get('helper.module');
The following user(s) said Thank You: ianspeed
14 years 1 day ago #76226
by ianspeed
Replied by ianspeed on topic Wishlist showing as a cart when not logged in...
Thanks Xavier,
Just one question? When you select send by email, is there a plan to allow an email address entry to send the link directly without having to copy and paste the link in manually in to an email?
Ian
Ian
14 years 16 hours ago #76321
by Xavier
Actually it's not possible, but I add it on the TODO list.
I think that this feature will be more user friendly.
