Set price-index to products purchase price
- Micke_skane
13 years 10 months ago #78982
by Micke_skane
Set price-index to products purchase price was created by Micke_skane
Is it possible to set a price-index to the products purchase price soo if I want to high/lower the outprice I only have to change the price-index?
As it is now I have to change each productprice.
If I got 4000 products it takes long time each time I want to change the price...
Exampel:
Product 1 = 10 dollar(purchase price)
Product 2 = 20 dollar(purchase price)
Product 3 = 30 dollar(purchase price)
Price-index = 2.0
Product 1 = 2.0*10 dollar = 20 dollar(customers price)
Product 2 = 2.0*20 dollar = 40 dollar("")
Product 3 = 2.0*30 dollar = 60 dollar("")
I change the price-index to 3.0:
Product 1 = 3.0*10 dollar = 30 dollar(customers price)
Product 2 = 3.0*20 dollar = 60 dollar("")
Product 3 = 3.0*30 dollar = 90 dollar("")
Exampel:
Price-index = 2.0
13 years 10 months ago #79012
by Xavier
Replied by Xavier on topic Set price-index to products purchase price
You can create a product custom field, which wouldn't be display to customer (just display in back-end form). The custom field would contain the increase quantity value.
After that, you can use a custom HikaShop plugin with a callable function which would just execute a SQL query.
This query would increase the product quantity by the value contains in the custom field. The query would be quite simple.
So in the backend, you would find a link in the plugin options, by clicking the link, you would execute the SQL query and increase the quantity of all your products.
- Micke_skane
13 years 10 months ago #79064
by Micke_skane
Replied by Micke_skane on topic Set price-index to products purchase price
Thanks for your replay but it´s not the quantity I would like to changes, it´s the price for each product i would like to change just by changing the index-value.
The index-value mayby could be 2.15 and next time it´s 2,27...
13 years 10 months ago #79177
by Xavier
I can work too via a plugin, and in this plugin, add a field in which you set the index-value.
Then clicking on the link in the plugin call a function which execute a sql query to update the prices in the database depending on the value of the previous field.
- Micke_skane
13 years 10 months ago - 13 years 10 months ago #79376
by Micke_skane
Ok, what plug-in should i use?
Is it possible to round the price so there will not be any decimals?
For example:
Price-index:2,1
Purchase price: 437:-
Outprice: 2.1*437:- = 917.7:-
Round the price: 918:-(incl. taxes)
Does this update even change to price without taxes and without the round-method?
This price-adjustment must be something that is quite common and should be something that is standard in Hikashop.
Choose if you would like to use a price-index, set the purchase-price for each product that is marked to use the price-index and save the product.
Next time just change the price-index to change the price for All products Or just change the productprice to adjust that productprice.
Would this be possible in a future version of Hikahsop?
For example:
Price-index:2,1
Last edit: 13 years 10 months ago by Micke_skane.
13 years 10 months ago #79401
by Xavier
This plugin you have to develop it, or post in the commercial jobs section of this forum or ask to a third developer.
You can round the prices with no problems, it just must be implemented in the function of the plugin.
I add this feature in our TODO list, but it don't think that it will be developed soon because we have a lot of functionalities to develop already.
And this one is not required by a lot of people.
Time to create page: 0.181 seconds
