Products disappeared
13 years 11 months ago #80121
by webhelpus
Products disappeared was created by webhelpus
Moved all setup from my server to clients server and the products don't show up in the category pages for any of the categories.
13 years 11 months ago #80169
by Xavier
Replied by Xavier on topic Products disappeared
And have you well exported and imported the database ? With all the data ?
Copy and paste all the files of your repository and images ?
13 years 11 months ago #80229
by webhelpus
Replied by webhelpus on topic Products disappeared
Yep. All the stuff is visible in the backend and only the products don't show in the front end. Direct links to products do produce results, but they are not automatically shown in the category view.
- Thank you received: 1778
13 years 11 months ago #80251
by Mohamed Thelji
Replied by Mohamed Thelji on topic Products disappeared
Then can you show us how did you configured your products and your category listing menu ("Hikashop->Display->Content menu->'Your category menu'" ? It would help us to understand what the problem really is.
13 years 11 months ago - 13 years 11 months ago #80258
by webhelpus
Sure, but it worked before the transfer
docs.google.com/a/webhelpus.com/file/d/0...bmVBcWhHMjFLeEk/edit
Last edit: 13 years 11 months ago by webhelpus.
13 years 11 months ago - 13 years 11 months ago #80263
by Mohamed Thelji
Ok,
Are you sure that you have products in the Bears'shopping Den category ? Can you show me by the same way as before the products that are in this category ? (through "Hikashop->Product").
Last edit: 13 years 11 months ago by Mohamed Thelji.
13 years 11 months ago #80265
by webhelpus
docs.google.com/a/webhelpus.com/file/d/0...Y1RaYndnT2hUNFU/edit
See, the products are there:
www.bearstitches.com/current/index.php/c...-hooty-blue?Itemid=0
But not if you look at the category:
www.bearstitches.com/current/index.php/p...egory/23-camera-bags
(Yes I realize that pic is enormous, but haven't got around to figuring out how to make it smaller without uploading a new pic.)
13 years 11 months ago #80347
by Xavier
I think that the problem come from your menu configuration, there is no associated module.
The associated modules are there to display the products of a category.
Thanks to create one and assign it to the menu.
The following user(s) said Thank You: webhelpus
13 years 11 months ago #80874
by webhelpus
Somehow the automatic associations didn't transfer over on the move and I had to manually add them. Now that I know what I'm looking for, that's not a big deal at all. It really helps me understand how this eCommerce extension works and makes me glad that I switched over from Virtuemart. I will be using HikaShop in all my clients websites.
