Display problem with content module
13 years 11 months ago #81501 by jan.chambers@fmcpaware.or
I am currently working in a test environment running Joomla 2.5.4 and Hikashop Business 2.0.0. My store uses a Hikashop category display module for navigation. This module is assigned to a position on the Joomla template, but is not an associated module for the Hikashop content menu. In Hikashop, the module is configured as a "List" under "Layout." I imported the product and category data into this server's database from another install of Hikashop. However, the menu module displays a series of weird little black boxes over its text. Please take a look at the attached screenshot. This same issue shows up when I create the products and the categories from scratch instead of importing them. I know very little PHP, but I'm otherwise technically inclined, familiar with Joomla, and willing to learn. Thanks in advance.
13 years 11 months ago #81632 by Xavier
These boxes come certainly from your template.
You will have to edit some CSS to remove them, you can find some documentation about how customize CSS here:
The following user(s) said Thank You: jan.chambers@fmcpaware.or
13 years 11 months ago #81690 by jan.chambers@fmcpaware.or
I have a live version of this site, which uses the same template, but with Joomla 1.6 and Hikashop 1.5.8. The issue with the module doesn't show up on that site. If it was a CSS issue, wouldn't the same problem be showing up on both sites? Either way, I'll check the CSS. Thank you for your quick reply.
13 years 11 months ago #81770 by Jerome
Do you have a link to your testing website ?
With the html page, we would be able to understand more your problem.
Thanks,
13 years 11 months ago #81951 by jan.chambers@fmcpaware.or
I uninstalled and then reinstalled Hikashop on the test site and rebuilt a test module in Hikashop from scratch. The display problem didn't show up anymore, so I upgraded my main site to 2.5.8 and its install of Hikashop to 2.0.0. The same display problem is now on the live site.
Here's the link to the page with the problem: www.fmcpaware.org/fmcpaware-store
I'm going to try recreating the module to see if that helps at all.
13 years 11 months ago #81954 by jan.chambers@fmcpaware.or
I unpublished the module on the main site. Users can make purchases, but I can't display that module until I get this problem fixed. Here's the link to the test site: www.nfmcpa.org/fmcpaware-store . I exported the hikashop-related database tables from the live site and imported them into the test site, so the module now has the same problem as mentioned before.
13 years 11 months ago #82062 by Xavier
Try this property in your template css file:
.panel h3.pane-toggler-down{ background-color: transparent !important; background-image: none !important; }
13 years 11 months ago #82143 by jan.chambers@fmcpaware.or
Thank you for the code. It didn't solve the issue when I inserted it into the CSS file for my website template, but when I inserted it into the CSS for the front-end Hikashop template, it worked perfectly. :cheer:
Thank you again for your help. Problem solved! B)
