backend display issue
13 years 10 months ago #85499
by naushad
backend display issue was created by naushad
13 years 9 months ago #85554
by Xavier
Replied by Xavier on topic backend display issue
Do you have changed something in the backend templates ?
Are you using a custom template and not a default one for the backend ?
Try to install HikaShop again over your old HikaShop.
13 years 9 months ago #85588
by naushad
Replied by naushad on topic backend display issue
Hi, I install it on fresh installation and it gives the same issue,
Also the one I have installed it now has a custom template but it should not affect the backend.
If I reinstall it, will i lose my categories and items and settings?
13 years 9 months ago #85609
by Jerome
Replied by Jerome on topic backend display issue
Could you reproduce the problem in the backend of our demo website ?
demo.hikashop.com/administrator/
13 years 9 months ago #85612
by naushad
hi, can I give you access to my demo site?
On your demo site is fine, but on mine: each installation I have the same issue,
Can I please have your email so i may give you access to the admin....
13 years 9 months ago #85622
by Jerome
You can send it by private message.
13 years 9 months ago #85627
by naushad
Actually sorry, my mistake I am using VTEM admin template and that is causing the issue, Do you help sort this out?
13 years 9 months ago #85653
by Xavier
Are the other components working fine with this template ?
Your template is overriding our views and broke the headings.
13 years 9 months ago #85658
by naushad
Well all other components, ( over 8 + ) work perfectly fine, but its just your component which has the layout broken,
Can you guys help me out or do i need to contact the template owner? If you guys can help. It would be great.
13 years 9 months ago #85675
by Eliot
Replied by Eliot on topic backend display issue
Hi there,
If the template is overing our view the only solution you have is to find the broken css in your backend.
Try to take a look at the css with a right click and your browser's inspect element function.
You must find some css rules which are override, adding some new css in your backend css file will then do the job.
If you have found these broken rules, you can also edit them like this (example):
to this
It will give the priority to our css code.
float:left;
float:left !important:
