Captcha does not work
13 years 8 months ago #86303 by gidgie
Captcha does not work was created by gidgie
Hi guys,
i am trying to enable captcha on forms. Downloaded and installed captcha plugin from Hikashop. Have it enabled, generated new set of keys ( just in case).
Also have captcha at global settings enabled, and capcha plugin that comes with joomla enabled, but no catpcha comes up anywhere.
what am I doing wrong????
JOomla version 2.5.6, hikashop version 1.5.7
We have done lots of customizations to hikashop, so installing latest version would be a very very long job :) ( just in case you were going to offer this option)
Thanks in advance!
Giedre
13 years 8 months ago #86309 by Mohamed Thelji
Hi Giedre,
Can you do a screenshot of the options of your captcha plugin ?
13 years 8 months ago #86466 by gidgie
Replied by gidgie on topic Captcha does not work
Hi Mohamed,
Screen shot is attached. Hopefully that will give you some indication to the problem.
13 years 8 months ago #86549 by nicolas
Replied by nicolas on topic Captcha does not work
The plugin is configured to display the captcha after the password field. Do you have a password field on your registration form ? If not then you should change it to display after the email field, otherwise, the captcha won't show.
Also, the joomla captcha plugin should be disabled as HikaShop replaces it.
Time to create page: 0.212 seconds
