Checkout/Add to Cart issue only from product view
13 years 6 months ago - 13 years 6 months ago #92641
by joem
Checkout/Add to Cart issue only from product view was created by joem
Hello, I have just installed Hikashop onto Joomla 3.03 and seem to be having an issue.
When I view an item from the category page, and choose add to cart, it seems to return to the same page but it does not indicate the item was added to cart. When I click on the product and try to add cart from the product page, I get a 500 error. Also, clicking on checkout also produces a 500 error -- I cant seem to find any other details.
Can someone please suggest the next step to resolving the issue? Thanks!
Last edit: 13 years 6 months ago by joem. Reason: Problem Updated
13 years 6 months ago #92647
by joem
Replied by joem on topic Checkout/Add to Cart issue only from product view
Hello - I have just found the PHP error, but I still would need some help -
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 32 bytes) in /home/forzasol/public_html/mysite.com/administrator/components/com_hikashop/classes/field.php on line 371
Please help - thanks!
13 years 6 months ago #92807
by Xavier
Replied by Xavier on topic Checkout/Add to Cart issue only from product view
The allowed memory size seems to be to low. Try to increase the value of the memory:
www.hostucan.com/webmaster-tutorials/increase-php-memory-limit
Are you using many fields, or many variants for the products ?
Time to create page: 0.149 seconds
