Ordering products manually doesn't work
13 years 2 weeks ago - 13 years 2 weeks ago #123775 by LAMF
-- url of the page with the problem -- : www.gobbe.se/index.php/hikashop-menu-for...ing/kategori/30-krok
-- HikaShop version -- : Business 2.2.1
-- Joomla version -- : 2.5.14
-- PHP version -- : 5.3.3
-- Browser(s) name and version -- : No matter all browsers show the same
-- Error-message(debug-mod must be tuned on) -- : No message
I need to order a bunch of products under a certain category so the are ordered in the way I want it. Not alphabetically or automatic. I need to sort them all manually but it seem impossible. First I added like half of the products in this category manually and all worked just fine and there was no problem to order them manually as it suites me.
Then I wanted to add the rest of the product by importing them as a csv comma separated list. So I did but all those imported products got the same category ID=0 so they aer not possible to order manually :(
How can I change it so it is possible to order my products manually so I get them in the correct order?
Micke
Last edit: 13 years 2 weeks ago by LAMF.
13 years 2 weeks ago #123784 by LAMF
Sorry again, it took quite a while to see the obvious. Anyway easiest way doing it in case anyone is blind as I was is to simply change the ordering by manually ading the numbers in the ordering column and save it. Voila!
Time to create page: 0.149 seconds
