- Thank you received: 4
Sorting Products by their Characteristics
13 years 1 day ago #125977
by kchahine
Sorting Products by their Characteristics was created by kchahine
morenadancewear.com.au/beta/
-- HikaShop version -- : Business
-- Joomla version -- :2.5
I have a set of products (to be entered) which are shoes. I created a characteristic for the sizes of these shoes. However, not all sizes are available for each model of shoes and I would like to give the client the ability to sort them according to the available sizes. Any idea on how this can be done!
regards.
regards.
- Thank you received: 1778
13 years 15 hours ago #126041
by Mohamed Thelji
Replied by Mohamed Thelji on topic Sorting Products by their Characteristics
You can do that by using Filters through "Hikashop->Display->Filter", you'll just have to set the "Apply on" option to "Characteristic".
Note that Filters are available through the business version of Hikashop.
The following user(s) said Thank You: kchahine
12 years 11 months ago #127249
by kchahine
Replied by kchahine on topic Sorting Products by their Characteristics
I am aware I have already said thank you but when trying I found that I could not find "characteristic" item listed when trying to use "apply on". Any idea?
12 years 11 months ago #127300
by Mohamed Thelji
Can you show me some screenshots of how did you configured your filter ?
12 years 11 months ago #127686
by kchahine
I managed to solve it. The problem was that I selected the default "type" field to be text but once I change it to checkbutton or other it worked like magic.
Regards.
Regards.
Time to create page: 0.250 seconds
