terms and conditions not work
12 years 11 months ago #127039 by rockettboost
Hello friends !
I ran into a problem.
I have a point "terms and conditions" which should appear in a popup window .
but the window does not appear, but instead the bottom of the site there is a blank space with <div class="modal hide fade".>
can you help me in this case ?
12 years 11 months ago #127101 by rockettboost
- adress is work fine on the same page*
maybe it's conflict with Acy Mailing ?
[IMG
12 years 11 months ago #127102 by rockettboost
error is still here when Acy is turned off
12 years 11 months ago #127137 by Jerome
There is no link with acymailing. It is just that some acymailing code is display below the modal initialization script.
You use the Bootstrap modals but you don't have the jQuery bootstrap modals library in your website.
Or your template completely mess up the jQuery initialization and the modal lib is destroyed.
It seams that you can't open any kind of bootstrap popup in your website, not only in HikaShop.
The modals are a Joomla 3 native function, the code you see is not added by HikaShop, it's added by joomla itself.
Please checkout your template, please check your scripts inclusions and please see in the joomla forum how to fix the bootstrap modals in your website.
Otherwise, you can change the modal used in HikaShop in order to use the "mootools" (squeezbox) one instead of the jquery bootstrap.
The following user(s) said Thank You: rockettboost
12 years 11 months ago #127140 by rockettboost
i enable mootool - and it worked .
thx
[IMG
12 years 11 months ago #127143 by rockettboost
Jerome , are you planning to use the jquery library in future ?
because the mootols has allways problems))
and use three libraries on the site, not very well
thx for your help !!! I appreciate it !
12 years 11 months ago #127236 by Jerome
What ?!
I am sorry but the bootstrap popup uses jQuery and in your website, it didn't work because of a wrong multiple inclusion of the jQuery library. So in your specific case, using mootools was the right thing to do.
Secondly, HikaShop uses jQuery. We do not include the library in the package for nothing...
I really don't understand what you are trying to say but I guess you have misunderstanding how HikaShop works and you remark is not appropriate.
12 years 11 months ago #127262 by rockettboost
Nothing personal Jerome, but I think that the framework should be one. and do not hang on the site a bunch of different libraries and wait for 3-4 seconds page load.
Have a good day )
12 years 11 months ago #127279 by Jerome
I still don't understand anything of what you are trying to explain.
Do you know that Joomla itself still use mootools and for most features the mootools lib will be load ?
Do you know that Joomla 1.5/2.5 does not include the jQuery library ?
Do you know that most of component which include jQuery does not check the joomla version and does not use the Joomla jquery lib so you can have several jquery inclusions for a single page ?
Please try to explain it better. I know that it's nothing personal but it is just impossible to understand your message which could be wrong interpreted.
12 years 11 months ago #127283 by rockettboost
forget
Time to create page: 0.212 seconds
