- Thank you received: 2
Bootstrap negates existing code for box hieght
- miracleecho
12 years 11 months ago #130625
by miracleecho
Bootstrap negates existing code for box hieght was created by miracleecho
Based on a previous post i had placed this code:
.hikashop_products_listing .hikashop_subcontainer {
min-height: 320px;
to make sure my product box heights were all the same size which worked fine as you can see by my first image. However, I had to change the back end general display to use bootstrap design in order to accommodate the way the products show up on tablets - portrait view (they were not wrapping correctly) now it appears my product names are not wrapping and when viewing on a standard monitor (see image 2) they are not sizing properly.
min-height: 320px;
12 years 11 months ago #130633
by Jerome
Replied by Jerome on topic Bootstrap negates existing code for box hieght
The problem is that the title of the product does not allow to be displayed on several lines.
So it uses a larger size and increase the width of his container. So the result is not something expected.
I think you have a CSS rule which forbidden the "word wrap" or something like that.
But it's not something in the HikaShop CSS file.
- miracleecho
12 years 11 months ago #130662
by miracleecho
Replied by miracleecho on topic Bootstrap negates existing code for box hieght
I am a confused. The first image has a wrapped title, and the only thing i did was turn bootstrap on in hikashop. I did not add or delete any additional CSS. So it appears turning on the bootstrap altered something?
12 years 10 months ago - 12 years 10 months ago #130801
by Xavier
Replied by Xavier on topic Bootstrap negates existing code for box hieght
Thanks to follow that tutorial in order to find from where this problem come:
As Jérome said, you probably have to find something related on the word wrapping in the bootstrap css file.
EDIT:
After looking at your other topic about this problem:
www.hikashop.com/forum/4-how-to/79472-pr...pping-pr.html#130809
It seems that you are using the list display type, thanks to try with the div one in the menu/module parameters.
You template is overriding our css properties, we set a width in percentage for this kind of listings, but on your page, it's missing.
EDIT:
Last edit: 12 years 10 months ago by Xavier.
Time to create page: 0.207 seconds
