Module to appear for one product list
12 years 10 months ago #130775 by joanne721
-- url of the page with the problem -- : amykandco.com/shop/photo-d-lights
-- Joomla version -- : 2.5
-- PHP version -- : 5.3.24
I have 3 product categories. I want to display a module on one of the category pages where the products are listed. But I don't want it showing up when a user clicks through to an individual product in that category. Currently, if I assign the module to the menu item for that category listing it shows up on the individual product pages.
Any help is appreciated.
Joanne
12 years 10 months ago #130829 by Mohamed Thelji
If you only want it to display above you category page, you should assign it to category page menu by :
- Going to your Module configuration page through your Joomla module manager page
- Setting the "Module Assignment" option to Only on the pages selected
- Only checking the menu where you want your module to be displayed (you product listing menu).
12 years 10 months ago #130887 by joanne721
I think I must have my shop set up incorrectly.
I have category listing menus that display all the products in a particular category and I have product listing menus that also display all the products from a particular category. I"m not sure what the difference is between them.
I have a button on the home page that directs visitors to the products listing (from a hidden menu) and a button in the nav bar that directs visitors to the category listing both of which have been configured to display the same way -- I was learning Hikashop when I set this up and was/still am confused.
Then there is a Hikashop default menu with both a Product listing menu item and Category listing menu item in it -- and I'm not sure why these are there or what they signify -- Hikashop must have created them automatically?
Regardless, no matter which menu item I assign the module to, it still shows up on the individual product pages when I click through from the products listing or category listing pages.
Is there documentation you can direct me to that explains the difference between Product listings and Category listings?
Thanks again in advance.
12 years 10 months ago #130924 by Xavier
We can't differentiate if we are in a listing or a product page with Joomla.
You can use the component Advanced module manager, it allow to display the modules where you want with more restrictions.
The following user(s) said Thank You: joanne721
Time to create page: 0.175 seconds
