- Thank you received: 1
Add to cart adds wrong product
- trogladyte
12 years 10 months ago #132135
by trogladyte
Add to cart adds wrong product was created by trogladyte
www.digitalguarddawg.com/rv/rv-1000/product
-- Joomla version -- : 2.5.16
-- PHP version -- : 5.3.x
I have 3 tabs under the product on this page. Accessories lists 2 allied products to the main unit. If you click Add to cart for the main product it just adds the first product under the accessories tab.
I have an identical type of set up here - www.digitalguarddawg.com/automobiles-tru...motive/pbs-i/product - and it performs as expected.
- Thank you received: 1778
12 years 10 months ago - 12 years 10 months ago #132163
by Mohamed Thelji
Replied by Mohamed Thelji on topic Add to cart adds wrong product
It's maybe a cache issue, can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin.
Last edit: 12 years 10 months ago by Mohamed Thelji.
- trogladyte
12 years 10 months ago #132231
by trogladyte
Replied by trogladyte on topic Add to cart adds wrong product
Definitely NOT the cache. It isn't on and never was.
The other pages that are working correctly are actually under this page (not the link as previously given) so I know it can work...
www.digitalguarddawg.com/motorcycles/rfi...y/dgd-kim-hd/product
- trogladyte
12 years 10 months ago #132239
by trogladyte
Inspecting the button with Firebug shows:
405 is the correct product code. If I remove the Accessories tab, the product is added correctly.
<input type="submit" class="btn button hikashop_cart_input_button art-button" name="add" value="Add to cart" onclick="var field=document.getElementById('hikashop_product_quantity_field_1');if(hikashopCheckChangeForm('item','hikashop_product_form')){ return hikashopModifyQuantity('405',field,1,'hikashop_product_form','cart'); } else { return false; }" style="zoom: 1;"/>
12 years 10 months ago - 12 years 10 months ago #132333
by Jerome
Replied by Jerome on topic Add to cart adds wrong product
edit
It is not possible to put a "add to cart" of another product in a tab of a product page.
There is a form in the product page which contain the all page. So when you click on the "add to cart", it is related to the current form.
Because you put a form into a form, it break the way that the HTML (and the forms) is processed so it send the wrong data to the server.
It is just not possible to put such data in the tab.
Or you have to modify the HTML so the other "add to cart" won't be include in the main form of the product page.
edit
Last edit: 12 years 10 months ago by Jerome.
- trogladyte
12 years 10 months ago #132507
by trogladyte
Sorry Jerome, I am really going to have to disagree. I have it working correctly on the very same site on this page (look under Harley Accessories tab):
The DGD-KIM-HD can be added to the cart correctly, although, despite the setting to the contrary, after adding to the cart the user is taken to the checkout. That's less of an issue, though I would rather it didn't.
However, the fact remains, this page adds correctly to the cart and www.digitalguarddawg.com/rv/rv-1000/product does not despite being set up in exactly the same way.
12 years 10 months ago #132652
Replied by nicolas on topic Add to cart adds wrong product
It's normal that it doesn't work. Your would tab system is displayed inside the product description which is displayed inside the product page form. And each product of your listing has also a form for its own add to cart. But you can't have a form inside a form in HTML. That's why it messes up.
The solution is to not have your tab system in the description but edit the show file of the view product and add custom code to add the listing (and the whole tab element if you want) outside of the form of the product page. Or you remove the add to cart buttons of the listing of products on the product page.
Time to create page: 0.210 seconds
