Problem with Manufacturer Display
12 years 10 months ago #133839 by 1fcb
-- url of the page with the problem -- : www.die-besten-weine-der-welt.de
-- HikaShop version -- : Latest business version
-- Joomla version -- :3
I am having problems with the display of products when filtering for manufacturers. I have created a menu that has manufacturers as only menu item. When clicking, it displays a list of manufacturers. So far, so good. Now, when clicking on one of the manufacturers, the products of that specific manufacturer are displayed. However, this display is different from the display I get when selecting a category display from a category menu. The manufacturer display has the Add to cart button on it and would not allow to navigate further down on the product details page.
You can see the difference on my homepage, when selecting on the left hand bar either "Wines sorted by Ratings" (showing the correct product layout) and "Weingüter" leading to the wrong product layout,
Can you please help me fixing this? Thank you very much in advance.
12 years 10 months ago #133902 by nicolas
That's normal. It just mean that you configured the products listing module associated with your manufacturer menu item like that.
Go in the menu Display->Content menus, edit your manufacturer menu item and then click on the associated modules link and there you'll have the options of your products listing and you'll be able to turn off the add to cart button and turn on the link to the product page.
Time to create page: 0.154 seconds
