Backend problems
- condorazul
12 years 8 months ago #140672
by condorazul
Backend problems was created by condorazul
mywebsite.com/mypage
-- Joomla version -- : 3.21
-- PHP version -- : x.x.x
I have two problems with backend:
1.- in prodcuts i want to see all the products so i select all the subelements, and access denied message is displayed.
2.- In regions, only shows 20 regions at a time so i have to go through 14 page to disable all except my country, is there any way to display all the regions so i can check them all.
- Thank you received: 1778
12 years 8 months ago #140690
by Mohamed Thelji
Replied by Mohamed Thelji on topic Backend problems
Can you show me some screenshots of the problems that you are having so that I can reproduce them on my end ? Also, can't you set the pagination of your "region" listing to "All" ?
- condorazul
12 years 8 months ago #140791
by condorazul
Replied by condorazul on topic Backend problems
12 years 8 months ago #140830
by Mohamed Thelji
1. Can you download the last hikashop version through our website, install it, and test it again ?
2.We just made a fix about this issue, so can you edit the file "administrator\components\com_hikashop\helpers\helper.php" , and replace these lines :
By :
jimport('joomla.html.pagination');
if($this->pageInfo->limit->value == $max)
$this->pageInfo->limit->value = $limit;
$pagination = new JPagination($this->pageInfo->elements->total, $this->pageInfo->limit->start, $this->pageInfo->limit->value);
if(HIKASHOP_J30) {
$pagination = hikashop_get('helper.pagination', $this->pageInfo->elements->total, $this->pageInfo->limit->start, $this->pageInfo->limit->value);
} else {
- condorazul
12 years 8 months ago #140873
by condorazul
ok both solved
Time to create page: 0.183 seconds
