Product Desciption disappears under right column
12 years 7 months ago #142714 by mdraeger
When on the product page, the description runs underneath my right column. How do I resolve this?
Alternatively, I've tried to turn off the description via modules but they don't turn off.
Where else do I do this?
Thanks,
Great support YTD!
Martin
12 years 7 months ago #142727 by Eliot
Hi martin,
A screenshot of the problem as well as a link to the page could be a big plus if you want us to help you.
You should check the css of the block containing the description and see if you can change something in there to force the width (like width-max)
12 years 7 months ago #142746 by nicolas
That's because you edited the file "show_tabular and changed the line:
<div id="hikashop_product_left_part" class="hikashop_product_left_part">
<div id="hikashop_product_left_part" class="hikashop_product_left_part" style="width: 500px; ">
while 500px is too big and goes below the right column. You should reduce that to 470px.
12 years 7 months ago #143232 by mdraeger
that worked, thank you. I thought that when I uninstalled and reinstalled Hikashop, it would reset everything.
thanks,
Martin
12 years 7 months ago #143364 by nicolas
If you do your changes via the menu Display>Views, you don't loose them, like your product data, or settings.
The following user(s) said Thank You: mdraeger
