- Thank you received: 1
Category display, but also showing products
12 years 7 months ago #142757
by mdraeger
Category display, but also showing products was created by mdraeger
With your support, the site is finally coming together and I am excited about the prospect of building more sites using hikashop. That said, I have a couple of more roadblocks.
The first is, my category landing page displays my categories perfectly - BUT it is also showing all my products below as well. I tried to turn off the appropriate module but with no luck. Could you provide some direction?
Martin
Martin
- Thank you received: 1778
12 years 7 months ago - 12 years 7 months ago #142804
by Mohamed Thelji
Replied by Mohamed Thelji on topic Category display, but also showing products
You should :
- Remove the associated module of the "associated modules" option of your category listing content menu configuration page ("Hikashop->Display->Content menus")
- Delete the associated module through "Hikashop->Display->Content modules"
You should :
Last edit: 12 years 7 months ago by Mohamed Thelji.
12 years 7 months ago #143230
by mdraeger
Replied by mdraeger on topic Category display, but also showing products
I can certainly do that but I am concerned that if I do, I will mess up other parts of my site. Can you confirm which module I should do this to? I saw 530 however when I test it by changing the type to list, it also impacts my reel view from the left menu as well. If I delete 530, will it also delete my view from the left nav?
Thanks,
Martin
Thanks,
Martin
12 years 7 months ago #143365
Replied by nicolas on topic Category display, but also showing products
Please provide a link to the page you're talking about and we'll be able to answer.
12 years 7 months ago #143569
by mdraeger
See
naturalsports.cloudaccess.net/natural-sp...ing-departments.html
All I want is the primary categories in the div. From there, people can either navigate with the left nav, or select one of the category icons and move to that category.
Thanks!
Martin
Thanks!
Martin
12 years 7 months ago #143633
by Mohamed Thelji
Hi Martin,
I just checked your website and as you said, the module that you'll have to delete will be the module which have the ID number 530 through "Hikashop->Display->Content modules".
Also, deleting this Hikashop module won't affect your left "departments" menu.
12 years 7 months ago #143687
by mdraeger
I did what you said, deleted 530 and ALL my products disappeared. What do I need to do to bring everything back?
12 years 7 months ago #143691
by mdraeger
Disregard as I figured out how to re-associate an existing module.
Time to create page: 0.194 seconds
