How to have two description fields for a product?
12 years 7 months ago - 12 years 7 months ago #143567 by markespositi
Hi.
I would like to have the result you see in the picture.
That is I would like to have the two description you see pointed by the two green arrows.
So I need TWO "description" fields in the product panel. Unfortunately, currently there is only one of it..
Any suggestion?
For example, in joomla it's possible to insert a "page break" in a HTML field and then it's possible to refer to one or to the other. Is there somethingh similar in Hikashop?
Thanks in advance.
Last edit: 12 years 7 months ago by markespositi.
12 years 7 months ago #143600 by Mohamed Thelji
The solution will probably be to :
- Create a text custom field of the "product" table through "Hikashop->Display->Custom fields"
- Set a the second description through your product page
- Edit the files of your "product" view to display this custom field through "Hikashop->Display->Views"
12 years 7 months ago #143655 by markespositi
Thanks. I did it.
I created a custom field named "Short Description" in the "Product" Table. Colomn name is "Description2".
Now, how to refer exactly to that custom fields in order to place correctly in the page editing Hikashop ->Display->Views?
12 years 7 months ago #143688 by Mohamed Thelji
You'll have to edit the "show_default" file of the "product" view of your front-end template through "Hikashop->Display->Views" and use some code like :
<?php echo $this->element->YourCustomFieldName; ?>
Time to create page: 0.266 seconds
