- Thank you received: 1
Need help adding products with a lot of options
- meleciovaldez
12 years 7 months ago - 12 years 7 months ago #145153
by meleciovaldez
Need help adding products with a lot of options was created by meleciovaldez
ok so I own a printing business and I want my customers to be able to see the price for my product. but the price of my products change with selection of different options. for ex my customer may choose "Business Cards" but then they still have to choose from these following options Stock, Dimensions, Coating, Corners, Color, Qty. After customers have selected the options I want my website to display the price. I've read that MySQL will be the easiest way to go about this? can this be done through Hikashop and am I on the right track with my Database? any help will be great. Thank you
Last edit: 12 years 7 months ago by meleciovaldez.
- Thank you received: 1778
12 years 7 months ago #145169
by Mohamed Thelji
Replied by Mohamed Thelji on topic Need help adding products with a lot of options
Can you give us more information through some screenshots of what do you really want to do ?
- meleciovaldez
12 years 7 months ago #146513
by meleciovaldez
Replied by meleciovaldez on topic Need help adding products with a lot of options
yeah I added a attachment on the original topic, every product has these options; Stock, Dimensions, coating, corners, color, quantity, when that is selected it outputs the price. for ex there is 3 kinds of stock when ever a stock is clicked the dimensions come out in the dimensions options then the coating for that product and so on and so on
12 years 7 months ago #146615
by Xavier
Replied by Xavier on topic Need help adding products with a lot of options
There is no default options in HikaShop to do that.
The price is automatically changed when selecting an option, but all the options are displayed at a time.
To display only one option, then the second one when the first is selected, then the next one, etc.
It will require custom code, adding css to set as display : none the options, and some javascript to change this display:none to display:inherit, when the previous option is value is selected, using the onchange javasscript function.
A good php / javascript level is required.
The following user(s) said Thank You: meleciovaldez
Time to create page: 0.180 seconds
