2 problems with links and tabular view
12 years 6 months ago #148493 by misa22
hello again :D
first problem
i have linkt to the produkt, and link looks like this
mysitename/produkt/produktname.html
when i have manufacturer enabled in produkt view the link is like this
mysitename/manufacturername.html
and i dont have that link to my site.
and i want to have link like this
mysitename/manufacturer/manufacturername.html
because i have that link :)
2 problem
compare produkt links problem
when i have produkcts in compare view
the products have links like this
mysitename/component/hikashop/produkt/produktname.html
how to make this looks like this
mystitename/produkts/produkt/produktname.html
3 problem - tabular
is posible to make another tab in tabular like video tab?
12 years 6 months ago #148501 by Mohamed Thelji
1. 2. Note that using "SEF url options" tab options through "Hikashop->System->Configuration->Feature" will probably help you.
3. The solution will probably be to add some code customization to add your "video" tab through the "listing_table" file of the "product" view through "Hikashop->Display->Views"
12 years 6 months ago #149791 by misa22
1.2. Sef url options dosent help in this problem.
3. I realy dont know good php :) to make this work :)
12 years 6 months ago #149857 by Xavier
Thanks to give us your settings regarding the SEF options.
Using an advanced sef manager components can probably help you in having the desired URLs.
For the Tab I suppose that you are talking about the product show page with the tabs.
So you have to edit the view "product / show_tabular" and add a tab by adding the following code in the "ul":
<li id="hikashop_show_tabular_NEWTABNAME_li" class="hikashop_tabs_li ui-corner-top"><a onclick="displayTab('hikashop_show_tabular_NEWTABNAME');" href="javascript:void(0);"><?php echo JText::_('NEWTABNAME');?></a></li>
And this code:
<div class="hikashop_tabs_content" id="hikashop_show_tabular_description"> ... </div>
In the content.
12 years 6 months ago #150246 by misa22
Ok so i add the firs code to ul. hika_tabs_ul and now tab apear :)
but where i must add the secound code?
In products content description?
I try to add this code in product description and the content in the<div class="hikashop_tabs_content" id="hikashop_show_tabular_description">
... - this contnent
</div> dosent show in video tab.
12 years 6 months ago #150304 by misa22
I think about create, new database...
because vide tab will have all products...
and product will have diffrent video
12 years 6 months ago #150325 by Xavier
Sorry my mistake, the code must be:
<div class="hikashop_tabs_content" id="hikashop_show_tabular_NEWTABNAME"> ... </div> I forgot a replacement. And you can place it after any other div with the class "hikashop_tabs_content".
To have different videos depending on the product, the easiest way is to create a new custom field in the "product" table via the menu Display > Custom fields. Then in backend for each product set his video url/path.
And in the view edition, in the tab set a path containing the url set in the custom field.
To get the content of a custom field you have to use code like:
$this->element->CUSTOMFIELDNAME
12 years 5 months ago #151388 by misa22
Hello again :)
OK i set up a tab - work ok.
i set up a div content - is ok
i put in div
<?php
echo ($this->element->customfieldname);
AND the video shows in video tab in tabular product view
BUT :)
The video shows in specification tab too :)
How to change that ;)?
12 years 5 months ago #151395 by misa22
and another problem, customtext delete iframe
12 years 5 months ago #151396 by misa22
ok secound problem is done :)
12 years 5 months ago #151392 by Xavier
Could you post the code you have for the tabs ?
Thanks to put it between the following tags [ code] ... [ /code] (without spaces)
12 years 5 months ago - 12 years 5 months ago #151522 by misa22
Sure :) here U go!
<div id="hikashop_product_bottom_part" class="hikashop_product_bottom_part show_tabular"> <div id="hikashop_tabs_div"> <ul class="hikashop_tabs_ul"> <li id="hikashop_show_tabular_description_li" class="hikashop_tabs_li ui-corner-top"><a onclick="displayTab('hikashop_show_tabular_description');" href="javascript:void(0);"><?php echo JText::_('PRODUCT_DESCRIPTION');?></a></li> <li id="hikashop_show_tabular_Video_li" class="hikashop_tabs_li ui-corner-top"><a onclick="displayTab('hikashop_show_tabular_Video');" href="javascript:void(0);"><?php echo JText::_('Video');?></a></li> <?php if($hide_specs == 0){ ?> <li id="hikashop_show_tabular_specification_li" class="hikashop_tabs_li ui-corner-top"><a onclick="displayTab('hikashop_show_tabular_specification');" href="javascript:void(0);"><?php echo JText::_('SPECIFICATIONS');?></a></li> <?php } if($status_vote == "comment" || $status_vote == "two" || $status_vote == "both" ){ ?> <li id="hikashop_show_tabular_comment_li" class="hikashop_tabs_li ui-corner-top"><a onclick="displayTab('hikashop_show_tabular_comment');" href="javascript:void(0);"><?php echo JText::_('PRODUCT_COMMENT');?></a></li> <li id="hikashop_show_tabular_new_comment_li" class="hikashop_tabs_li ui-corner-top"><a onclick="displayTab('hikashop_show_tabular_new_comment');" href="javascript:void(0);"><?php echo JText::_('PRODUCT_NEW_COMMENT');?></a></li> <?php } ?> </ul> <?php if(!empty($this->element->extraData->bottomBegin)) echo implode("\r\n",$this->element->extraData->bottomBegin); ?> <div class="hikashop_tabs_content" id="hikashop_show_tabular_description"> <div id="hikashop_product_description_main" class="hikashop_product_description_main"> <?php echo JHTML::_('content.prepare',preg_replace('#<hr *id="system-readmore" */>#i','',$this->element->product_description)); ?> </div> <span id="hikashop_product_url_main" class="hikashop_product_url_main"> <?php if (!empty ($this->element->product_url)) { echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>'); } ?> </span> </div> <div class="hikashop_tabs_content" id="hikashop_show_tabular_Video"> <?php echo ($this->element->video); ?> </div> <?php if($hide_specs == 0){ ?> <div class="hikashop_tabs_content" id="hikashop_show_tabular_specification"> <?php $this->setLayout('show_block_dimensions'); echo $this->loadTemplate(); if(!empty($this->fields)){ $this->setLayout('show_block_custom_main'); echo $this->loadTemplate(); } ?> </div> <?php } if($status_vote == "comment" || $status_vote == "two" || $status_vote == "both" ){ ?> <form action="<?php echo hikashop_currentURL() ?>" method="post" name="hikashop_comment_form" id="hikashop_comment_form"> <?php if(!empty($this->element->extraData->bottomMiddle)) echo implode("\r\n",$this->element->extraData->bottomMiddle); ?> <div class="hikashop_tabs_content" id="hikashop_show_tabular_comment"> <div id="hikashop_product_vote_listing" class="hikashop_product_vote_listing"> <?php echo $layout_vote_listing; ?> </div> </div> <div class="hikashop_tabs_content" id="hikashop_show_tabular_new_comment"> <div id="hikashop_product_vote_form" class="hikashop_product_vote_form"> <?php echo $layout_vote_form; ?> </div> </div> </form> <?php } ?> <input type="hidden" name="selected_tab" id="selected_tab" value="hikashop_show_tabular_description"/> <?php if(!empty($this->element->extraData->bottomEnd)) echo implode("\r\n",$this->element->extraData->bottomEnd); ?> </div> </div>
Last edit: 12 years 5 months ago by misa22.
12 years 5 months ago #151524 by Xavier
The code seems to be correct.
Could you give us a link to a product page with that problem ?
12 years 5 months ago #151687 by misa22
i send U private message :)
12 years 5 months ago #151665 by Xavier
Ok now I see why that's happening, that because in specifications it list all the custom fields, and because the video is a custom field so it appear in the specifications.
To avoid that you will have to edit the view "product / show_block_custom_main" and put an if condition to not display the field if it's the video one. Something like:
if($fieldName == 'VIDEOFIELDNAME') continue;
After:
foreach ($this->fields as $fieldName => $oneExtraField) {
The following user(s) said Thank You: misa22
12 years 5 months ago #151724 by misa22
it works :) beutufill :) Thank U!:)
Time to create page: 0.285 seconds
