- Thank you received: 7
Module under products not displaying
12 years 6 months ago #148761
by Dibben
Module under products not displaying was created by Dibben
Hi I have set the module under products to display in hikashop config and same in hikamarket. Now the same module is showing fine in hikamarket but not at all in hikashop. I think the module must be ok as it works in hikamarket. Please see attached the module selected in hikashop and the module config...
It should be showing on this page:
www.warestreetmarket.com/newsite/Browse-...tage-button-jar.html
It shows fine on this page:
www.warestreetmarket.com/newsite/Artist/vendor/show/cid-2.html
However for the second one as you know that is hikamarket.
Alex
Alex
12 years 6 months ago #148826
Replied by nicolas on topic Module under products not displaying
Your module is configured to display "related products" on the product page.
However, on your "vintage button jar" product, there are no related products:
www.warestreetmarket.com/newsite/adminis...roduct&task=edit&cid []=1
So it is normal that no products display below the product page with that module.
Time to create page: 0.163 seconds
