PER_UNIT display
12 years 5 months ago #151091 by nijan
PER_UNIT display was created by nijan
1. Is it possible to have more than one PER_UNIT value ?
---> For example I would like to display "kg" for product A and "à la pièce" for product B.
2. If PER_UNIT for product B is displayed is it possible to hide de price ?
Thanks !
12 years 5 months ago #151127 by nicolas
Replied by nicolas on topic PER_UNIT display
1. Yes, it's possible. You need to follow the instructions of the section "I sell packed products, how can I change "each" text in the product page ?" of our FAQ:
www.hikashop.com/support/support/documen...on/106-faq.html#tran
2. That would require to customize the view file "listing_price" of the view "product" via the menu Display>Views.
The following user(s) said Thank You: nijan
12 years 5 months ago #151265 by nijan
Replied by nijan on topic PER_UNIT display
I created a custom field (see Issue_HikaShop_09).
In my product I select for example "Méthode de vente - le kilo" (see Issue_HikaShop_08).
In the frontend, I have 2 problems : I would like to replace "l'unité" by "le kilo" (see Issue_HikaShop_07 & 10).
And for information I didn't changed the listing_price.
I only find the following line :
echo '<span class="hikashop_product_price_per_unit">'.JText::_('PER_UNIT').'</span>';
Greetings !
12 years 5 months ago #151318 by Mohamed Thelji
Replied by Mohamed Thelji on topic PER_UNIT display
The solution will probably be to replace that line :
By something like :
echo '<span class="hikashop_product_price_per_unit">'.$this->row->mthodedevente.'</span>';
Time to create page: 0.184 seconds
