- Thank you received: 2
How Can I Assign Modules To Individual Products
- dancingkazzaf
12 years 5 months ago #152484
by dancingkazzaf
How Can I Assign Modules To Individual Products was created by dancingkazzaf
Is there a way that we can assign a normal Joomla module (Custom HTML with an image and links for example), to specific product pages, because as they are all made within HikaShop, they don't have menu items to assign the modules to.
Any help would be greatly appreciated because this is a feature we would really like to use for our current client and possible others in the future.
- Thank you received: 1778
12 years 5 months ago #152525
by Mohamed Thelji
Replied by Mohamed Thelji on topic How Can I Assign Modules To Individual Products
The solution will probably be to control the display of your module regarding the menu where you are by using the "Module assignment" option through your Joomla module configuration page.
Also if you want your module to display only through some product page using the Advanced module manager will probably do the job.
Time to create page: 0.174 seconds
