a deeper nested product level
12 years 5 months ago #153460
by lidacha
a deeper nested product level was created by lidacha
www.etk-mood.nl
-- HikaShop version -- : HikaShop Essential: 2.3.0
-- Joomla version -- : 3.2.3
-- PHP version -- : 5.4.27
-- Browser(s) name and version -- : Safari 7.0.2
-- Error-message(debug-mod must be tuned on) -- : n/a
+ Menu extension -- : Skyline Accordeon Menu (ExtStore)
I hope you can help me with the following. I search the forums, but could not find a similar problem.
Anyway, see screenshots.
The first one displays the content as I can display it now, the second screenshot shows the table I need to display under each item. This table contains a list of article numbers with a description, a price, the discounted price and the possibility to select one to add it to the shopping cart.
So I need to go one level deeper until I can select the final product to buy.
I hope I explained it well enough.
Hope you can help me!
Kind regards,
Lida
Kind regards,
Lida
12 years 5 months ago #153492
by Xavier
Replied by Xavier on topic a deeper nested product level
To have this kind of display, you have to set the product "SUP-PRO-LED" as a category, then create as many products as there are variations of this product.
Then select the "table" display in the associated module of the category listing menu in order to display all the products as desired.
To resume:
SUP-PRO-LED = Category with the product description.
Each variants = products in that category
Display type = table.
Hope this will help you.
To resume:
12 years 5 months ago - 12 years 4 months ago #153756
by lidacha
Replied by lidacha on topic a deeper nested product level
Thank you very much Xavier.
Sorry for the late reply, but I wanted to try it first.
I thought I needed to display the category as a product because I needed to add images, photos, files before the actual products and also did not think I could display them on the same page.
But having set it up as you suggested, I think it will work. I installed and added a Tabs plugin on the category page to be able to add my files and photos there.
Now still trying to get the display the way I want. A lot of searching and trial and error, and I might come back here, but satisfied for now!
I appreciate your help and fast response very much, thanks again!
Last edit: 12 years 4 months ago by lidacha.
Time to create page: 0.213 seconds
