Custom Products
12 years 4 months ago - 12 years 4 months ago #155625
by lwlbar
Custom Products was created by lwlbar
I am trying to figure out the best way to adapt with hikashop for "custom" products. I will try to explain what I am trying to achieve....
For example, I wish to sell windows online however these can be custom dimensions so there is no "set" price. Instead the price is in function with the surface area and then the finishings chosen. The finishings aspect isn't a problem as this can be set up with using the hika options features, but I can't see the best way (if there is any) in dealing with unique product items. Ideally this type of feature would allow input fields for height and width for example, but I am sure is more complicated than just that.... :blink: .
If anyone has any ideas as to how to approach this I am all ears!
kindly
Luke
kindly
Luke
Last edit: 12 years 4 months ago by lwlbar.
12 years 4 months ago #155672
by Xavier
Replied by Xavier on topic Custom Products
With HikaShop, you can use the variants to have different sizes, colors, etc.
The limit is that the values are fixed by you, and not by the customer, so if, for example, you have sizes 10 / 20 / 30 and the customer wants 25, this size will not be available. If you use custom fields, the price will not be calculated automatically.
So, you will need a plugin. A plugin based on custom fields which will update the price depending on the values in these custom fields. It require PHP knowledges to make this kind of plugin.
Here is a link to the documentation:
hikashop.com/support/documentation/62-hi...r-documentation.html
Time to create page: 0.171 seconds
