- Thank you received: 1
Hot to resolve this problem? Vote overlying button
- andreasuriani
12 years 4 months ago #158111
by andreasuriani
Hot to resolve this problem? Vote overlying button was created by andreasuriani
photostore.andreasuriani.com/index.php/p...ry/16-luoghi-e-citta
Hi All,
i've this problem in container view: the vote overlying the bottom!
How to fix it?
Hi All,
How to fix it?
12 years 4 months ago #158116
by Jerome
Replied by Jerome on topic Hot to resolve this problem? Vote overlying button
You will have to customize your CSS ( www.hikashop.com/support/support/documen...ize-the-display.html ) to change/add some rules.
My suggestion will be to change the "line-height" (or margin/padding) for the class "hikashop_product_stock".
The button container does not react correctly but it's because of some of CSS rules of your template, so you have to fix it using custom CSS (in HikaShop or in your template).
- andreasuriani
12 years 4 months ago #158238
by andreasuriani
Replied by andreasuriani on topic Hot to resolve this problem? Vote overlying button
hi Jerome,
thanks for your reply.
Can you kindly write some example in CSS?
Sorry but i'm not a good programmer for CSS
Thanks a lot
And
Thanks a lot
And
12 years 4 months ago - 12 years 4 months ago #158244
by lousyfool
Replied by lousyfool on topic Hot to resolve this problem? Vote overlying button
.hikashop_subcontainer .hikashop_product_stock {
margin-top: 18px;
Last edit: 12 years 4 months ago by lousyfool. Reason: (...) removed
- andreasuriani
12 years 4 months ago #158278
by andreasuriani
Great! it works perfectly!!!
Thank you very much!
and
and
Time to create page: 0.202 seconds
