Selected product characteristic not in Cart
12 years 4 months ago #158715 by Genusskanzlei
-- url of the page with the problem -- : www.genusskanzlei.at/shop/
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.2.4
-- PHP version -- : 5.4.24
-- Browser(s) name and version -- : Chrome Version 35.0.1916.114 / Firefox V 29.0.1
Hi!
I have a product set with different variant. Everything is set correct as described in all the documents and forum posts I've read. When I select the variant the picture changes without a problem but when I add this variant to the shopping Cart it doesn't add the selected product. Instead it adds the product set as default. :(
This it the link to the product (characteristic name: Sektbombe Manschetten)
www.genusskanzlei.at/shop/index.php/unse...9-sektbombe-neu-jahr
I also noticed that the URL doesn't change as the variants are selected. 379-sektbombe-neu-jahr is the defauft.
Attached are pictures of my configuration for this product.
I don't know what else to do.
Thanks in advance for the help!
12 years 3 months ago #158797 by Mohamed Thelji
I just tested it on my end and it worked fine, can you only set one picture for your main product and make sure that you have set different pictures for your product variants ?
Time to create page: 0.153 seconds
