Formatting Products Page
12 years 3 months ago #161269 by reedstickets
-- url of the page with the problem -- : casesmithcustoms.com
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.3
-- PHP version -- : x.x.x
-- Browser(s) name and version -- :Chrome
I am having difficulties getting my products page to display correct. I create products (since I only have a few different ones with many different sizes, variants and options) through the menu and then add a product from hikashop through the menu..
The problem I have is the page does not format correctly , the Hikashop product display seems to be being added to the right column of the site instead of the body.. When I try to add standard items to the right column of my site such as login or menu they show right next to the left column of the site and then the Hikashop product shows up to the right of the two columns of the site...
If I do not use a right column and only the left column the product display better but it extends way to far and needs to be "padded or something, but I really want my right and left columns and the Hikashop product to sit within the body of the site, well formatted between the right and left columns of the site...
I have tried everything but cannot get this to look good at all..
Thanks for any help...
12 years 3 months ago #161338 by nicolas
Replied by nicolas on topic Formatting Products Page
I don't see the problem on your website:
take.ms/WflAE
I see a left and a right column on the product page, and the content of the product page in the middle.
It looks fine to me.
12 years 3 months ago #161339 by reedstickets
yes, I was able to fix it late last night, a template problem in template manager fixed the correct layout...
I am just back on working on the site now... so thanks for the responce..
I have checked online looking for a way to change the "add to cart " button... I would like it to look like your demo site but I have no luck..
It seems the code needs to be changed here
.hikashop_product_quantity_main .hikashop_product_stock .button
in front end CSS but for the life of me cannot find this in the source CSS file on the demo site or on mine..
I am a bit lost, can you explain to me how I can get my add to cart for products pages to look like the demo site?
Thanks,
12 years 3 months ago #161346 by nicolas
You indeed need to add custom CSS in the frontend CSS of HikaShop for that.
The exact CSS will depend on what you want.
On our demo website, we added:
.hikashop_product_quantity_main .hikashop_product_stock .button { color: #167e93 !important; font-weight: bold; background-image: url(../images/add_cart.png); background-repeat: no-repeat; background-position: right; height: 32px; padding-right: 40px !important; background-color: transparent; cursor: pointer; }
So first, it's normal that you don't see .hikashop_product_quantity_main .hikashop_product_stock .button in the default CSS, since you need to add it :)
Second, you changed the button display from "normal" to "css", and thus you should use .hikashop_product_quantity_main .hikashop_product_stock a.hikashop_cart_button instead of .hikashop_product_quantity_main .hikashop_product_stock .button to customize the CSS of the add to cart button.
12 years 3 months ago #161435 by reedstickets
Okay, sort of got it...where do I get the images for it though, also how about the + and - section...
Lastly,,on your checkout it goes to a proceed to checkout or continue shopping screen once added to cart... how do I add that?
Thanks for the help,
12 years 3 months ago #161436 by Xavier
Replied by Xavier on topic Formatting Products Page
This tutorial can help you to find the desired properties to edit, etc:
hikashop.com/support/support/documentati...ize-the-display.html
For the popup when adding a product to the cart, there is an option for that in Configuration > Main > Cart > After a product is added to the cart.
Time to create page: 0.197 seconds
