Customize Product Quantity + and - at product Page
12 years 3 months ago #162194 by reedstickets
-- url of the page with the problem -- : casesmithcustoms.com
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.3
-- PHP version -- : x.x.x
-- Browser(s) name and version -- :Chrome
I was able to customize the add to cart button a bit but how do I get to the product quanity + and - siigns and add some images or buttons for them?
Thanks for any help,
Reed
12 years 3 months ago #162207 by lousyfool
CSS seems to be no secret to you anymore, so that's good. Refer to the documentation for more, particularly for modifications affecting HTML see here: www.hikashop.com/support/support/documen...-display.html#layout
More can't be said as we don't know what exactly you want to do.
The following user(s) said Thank You: reedstickets
12 years 3 months ago #162217 by nicolas
As lousyfool said, you can do that with some simple CSS.
For example:
.hikashop_product_quantity_field_change_plus{
background-image: url(/images/plus.png);
color: transparent !important;
That will convert the minus sign into a plus.png image that you need to upload in the images folder. Then you might need to specify a height/width as well.
12 years 3 months ago #162387 by reedstickets
Thanks, I pretty much have the site tweaked to my liking...
Only other question I have is about button styles... Is there any documentation on how to change button styles and colors or can you point me to the piece of code which can be changed around each button in "display" "Views"?
Thanks for the help!
12 years 3 months ago #162390 by Xavier
You can simply customize it with some css properties.
Here is some documentation which could help you:
hikashop.com/support/support/documentati...ize-the-display.html
Time to create page: 0.199 seconds
