Remove product from shop front when out of stock
12 years 2 months ago #164086 by lt635
Not sure if this is the correct forum category....
I need products with no stock to be automatically removed from the shop. I was hoping that by setting 'Display out of stock products' to 'no' that I would achieve this but that does not seem to work. I have also set the 'Update the product stock on confirmed status' to 'yes'.
Example:
www.fsfightgear.com.au/website/index.php...oodley-walkout-shirt
The stock is setup in the variant and not the main product, ie 1 x small, 1 x large.
I was reading the forum post below which seems to have the same issue:
www.hikashop.com/forum/import-export-csv...with-zero-stock.html
I would also like the same for category, if a category is empty it will not be displayed in the frontend.
Is there anyway I can achieve this?
Thank you
Kind regards
Lene
12 years 2 months ago #164102 by Mohamed Thelji
Hello Lene,
1. If you have a product with variants which have stocks and variants which don't, the product will show so that your customer can at least purchase the variants in stock.
2. For your categories : you'll have to edit your category listing content menu/module, through "Hikashop->Display->Content menus/modules", and use the "Only display categories with products" option
12 years 2 months ago #164185 by lt635
Hello Mohamed,
1. With the product it was the problem you listed in point two. I went into the product listing menu and set it to not show out of stock so it is now being removed. (There was no variant left in the example I had.)
2. I tried the same for categories, but that is not working. I am using the Accordeon from Joomlack for the sub-menu, but that is only picking up the menu listing so I cannot see that that should be the problem. All settings are set in Menu and Hikashop category menu.
Lene
12 years 2 months ago #164228 by Xavier
2. They potentially don't manage this kind of feature. If you try with a default HikaShop menu / module the empty categories will not be displayed.
12 years 2 months ago #164312 by lt635
Ok, that is fine. Is there a way to have a message show only when a category is empty? Something like 'sorry, currently no items available in this category'?
Lene
12 years 2 months ago #164325 by Mohamed Thelji
Hello Lene,
I think that you'll ind your answer through that thread : www.hikashop.com/forum/4-how-to/55625-em...mpty-categories.html
Time to create page: 0.234 seconds
