Wrong link from to the product detail side
12 years 2 months ago #164879 by Rokell
-- url of the page with the problem -- : 5-elemente.org/33/de/horoskope.html
-- HikaShop version -- : 2.3.1
-- Joomla version -- : 3.3.1
I have a strange problem with on product link from the category view to the detail view.
All but one products in the category:
link to their correct detail view side.
Only the 4th product '12 Monatsvorschau' links to a product in another category when you click on it. The URL is correct, but it shows the details of another product.
I checked the assigned categories, but the settings are ok.
Could you please point me into the right direction?
Roger
12 years 2 months ago #164928 by Xavier
That's because you have removed the id from the urls in the sef settings of HikaShop, and your product name start with a number.
So the system think that this number is an id, that's why your are not redirected to the correct product page.
Thanks to edit the name in order to not have numbers at the beginning, or turn off the option to not have id in urls.
The following user(s) said Thank You: Rokell
12 years 2 months ago #164934 by Rokell
Thanks Xavier, that fixed the problem.
Best
Roger
Time to create page: 0.214 seconds
