HikaShop problem with translation
12 years 2 months ago #165816 by shpuser
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.5.9
After login i don't see anymore flags from falang to do translations: prntscr.com/47lqpq , falang database driver is active, for other translations i use joomla multilang. system... what can be the problem here?
12 years 2 months ago #165821 by Jerome
What is your HikaShop configuration for the multi language ?
www.hikashop.com/support/support/documen...onfig.html#languages
What is your falang version ?
12 years 2 months ago #165878 by shpuser
This setup was in my configuration disabled, but after installation it was active... Falang version is 1.4.0
12 years 2 months ago #165898 by Xavier
If you have no more the flags, so it is because FaLang is no more installed/enabled.
Or the option to activate the edition of content in multiple languages is disabled.
Or you have only one language published.
If all the previous points are correct, thanks to give us a backend access via private message with a link to that topic.
Time to create page: 0.169 seconds
