- Thank you received: 1
Same product description for all products!
- andreasuriani
i would like to create the same product description for all products (i'm selling just one kind of product but with more options)
How can i do this?
Obviously, for each language.
Thanks in advance
Andrea
The simplest is to edit the file "show" of the view "product" via the menu Display>Views and add at the beginning something like that:
- andreasuriani
but, in 'My description in english? can i put a HTML code?
Because, description has a table and image inside.
Andrea
Yes, you can.
And you can also use Joomla tags.
- andreasuriani
i've tried to put at the beginning the code, but it dosn't work.
Where is the issue?
Andrea
If you don't see any change, then it means that you're not editing the view file for the current template on your frontend. Please make sure that you're editing the view for the template you're using when you're in the menu Display>Views.
- andreasuriani
Nothing happened.
Can you help me?
Andrea
Please provide a backend access via our contact form so that we can check your settings and the change:
www.hikashop.com/contact-us.html
Please provide a link to this thread in your message
- andreasuriani
Andrea
I checked the code and there was a PHP misspelling in the code that Nicolas provided you which made an error.
I fixed the code in the Nicolas post and I put it in your "show" view in order to provide you a working sample.
I saw that you're using some variants. Please note that if you put a description in the variant, it won't be override by the code we provided you (it will require other kind of code to override the variants' descriptions)
- andreasuriani
thanks for reply and your help. Don't worry about variants because i'd like to write the options in main description.
Many thanks!!
Andrea
- andreasuriani
is it possible include in this code another code? I mean, the code works perfectly, but i'd like to create 2 kinds of description 1of all products (called global) and 1 of single product.:
Example:
Product 1
Description (Input on product insert) : Bla Bla Bla (Ita) and bu bu bu (Eng)
Show product on FrontEnd:
Product 1 (ITA)
Bla Bla Bla
Description global
Is it possible?
Andrea
I don't understand your message or what your want to achieve exactly but : Yes, it's possible.
You can use a product custom field in order to know if it's "global" or not "global".
It will require some PHP/development skills.
- andreasuriani
We already are far from standard user support here.
If you need someone to do custom development for you, I would recommend that you request a quote to our partners ( www.hikashop.com/home/our-partners.html ) and/or via our commercial jobs forum so that a third party developer can do that for you.
