Dynamic Badges on same position?
12 years 2 months ago - 12 years 2 months ago #166325
by veeco
Dynamic Badges on same position? was created by veeco
Hello
is it possible to make the badges dynamic on same position?
for example:
in the pic, i used 2 badge "new item" and "promo"
the "new item" badge is on top right position while the "promo" is on bottom right position
i want both badge on top right position and displayed like the 3rd product's badge
right now, if i place both badge on top right, one of the badge will be on top of the other badge
edit:i just noticed that you can't put 2 badges on 1 position [only the last one showed]
any solution?
for example:
any solution?
Last edit: 12 years 2 months ago by veeco.
12 years 2 months ago #166363
Replied by nicolas on topic Dynamic Badges on same position?
Yes, if you put two badges on the same position, only the last one will be shown.
So you need to put them on different positions.
There is no solution to have several badges on the same position and have them change position when the position is not available for the current product. You would have to edit the file administrator/components/com_hikashop/classes/badge.php in order to handle that if it's not easy even if you're a developer...
The following user(s) said Thank You: veeco
12 years 1 month ago #166431
by veeco
Replied by veeco on topic Dynamic Badges on same position?
Time to create page: 0.174 seconds
